QUOTE(JeffBowlsby @ Aug 3 2023, 10:38 PM)
The factory schematic has the answers. You will see that 72 was a transition year for this circuit. 70-71 did not have the circuit at all. 72 had the circuit in the ignition harness, which connects to the main harness at the relay board. There would have been a single wire connecting to the ignition harness, connected to the oil temp sender, I am not sure of its routing. 73-76 had the circuit in the main harness from below the battery area to the center console, where it connects to the center console gauge harness, and a separate wire from the sender to the connection under the battery tray.
Maybe there is a 72 owner here, with the factory oil temp gauge and wiring in place that may shed light on this setup, it would be good to see it.
Thanks Jeff, I've spent more time on the schematics than I care to admit lately and could not find the circuit there (I'll look at the ignition area again though), and this '72 certainly did not have the wire at the engine compartment section of the harness. It does have other early '72 items tho, like early doors and roof, etc. it's MY 05/72 , so that makes since.
I do have a complete '73 Harness that has the temp sensor wire ..and looking at that harness, yes the single wire went over to the passenger's side with the 4 reds to the battery area (thanks for confirming). I questioned this because the temp sender is over on the front left of the engine (doesn't seem logical), but I'm looking at all this stretched out on the lawn. Did it just shoot back across all the heat exchangers on the R side, back over to the sender
, I mean it makes no difference really - as I can choose the best path now. Hmm, but what might that be
, that's the question. Ideally it would come out of the snorkle somehow. Maybe I'll drop it out of the top of the snorkle solo, down thru the rubber engine seal. I'll figure it out - thanks again.
