I am been using 914 world for awhile seeking help on various things. Today, I thought I'd post about removing the fuel tank. Thanks to another member I was encouraged to take on this task in order to replace the German fabric covered rubber hoses that cannot tolerate ethanol. I was surprised how simple this task is. After syphoning out the fuel you remove the expansion tank, then unplug the fuel gauge, remove the holding strap and the tank comes right out!
A couple of observations for anyone that is going to do this. First, you do NOT need to remove the access panel under the car as indicated in the Haynes manual. There is enough slack in the lines to remove them when you lift the tank out. Second, make sure you mark the hoses! My 914 is a 75 with D Jetronic fuel injection so there are two lines to/from the fuel tank. One goes to the fuel filter, the other is the return (damper). I marked the lines on the tank but failed to note which hose went where where they connect to metal lines going through the passenger compartment! Also, replacement lines are 5/16 with the SAE R30 7 spec to resist ethanol. There is also a 1/2 inch line of about 2 feet that goes from the fuel filter to the fuel pump yet the line from the fuel pump is 5/16. Why? I have no idea.
Hope this helps someone!
