QUOTE(Dustin @ Aug 9 2023, 06:49 AM)
not adjusting means running lean and increased wear or damage to your new motor.
I've heard this before. But, why does running lean lead to increased wear or damage?
Lean condition will make the car run poorly ,but the worst problem is overheating and resulting high oil temps ,this also leads to cylinder head failure ,burnt /broken exhaust valves and valve seats that come loose .
Engine oil will become too thin and not provide sufficient lubrication to bearing ,
IMO probably the worst thing to happen to an aircooled engine .
