NARP74
Aug 16 2023, 11:47 AM
One of my front torsion bar bolts was replaced with a normal bolt. I am going to get a replacement like below. What is the replacement procedure?
Wheels off the ground?
Count turns of the bolt?
Measure something?
Any tension to worry about?
https://pmbperformance.com/products/torsion...ff135&_ss=r
Aug 16 2023, 12:40 PM
Jack it up, replace, get close to what you think it needs, drive it around the block, readjust until you are happy.
brant
Aug 16 2023, 01:34 PM
I’d mark the bolt with a sharpie and count the rotations. Maybe measure ride height at that corner to the front chassis before removal
Try to maintain ride height or your changing alignment slightly
technicalninja
Aug 16 2023, 03:35 PM
"Count the turns" may not work properly with a non-original bolt.
Measure ride height and re-create same measurement is how I'd skin that cat.
Drive around and adjust is also good advice and then "have an alignment done" is also a reasonable suggestion.
Adjusting front ride height on an old rusty 70 914 is how I first learned about blood poisoning.
Makes all the veins/arteries stand out like a road map on your arm...
Front yard mechanic
Aug 16 2023, 05:03 PM
Wheels off the ground makes it easier to see and turn the bolts. Drop the jack bounce a couple of times and measure the inside of the fenders to the ground. Go for a run and readjust
bkrantz
Aug 16 2023, 08:40 PM
Best practice is to check corner weights. Adjust the torsion bars first to get the ride height you want, and then balance the weight totals for front left plus rear right with front right and rear left. Raising the ride height on a front corner slightly makes it carry more weight. Each diagonal total should carry 50% of the total car weight.
targa72e
Aug 16 2023, 10:17 PM
I am with others, measuring fender height is probably the best way to get it back to same place. The threads of the bolts will be the same but the contact point to the adjuster might be different between bolts. It doesn't take much difference at the bolt to make a big difference in height. Long term when you have all the suspension sorted a corner balance and alignment is the final step to best handling.
john
Geezer914
Aug 17 2023, 04:22 AM
It is better to measure the ride height from the center of the torsion bar caps.
jim_hoyland
Aug 17 2023, 08:48 PM
PMB has several other related parts…
brant
Aug 18 2023, 11:10 AM
QUOTE(Geezer914 @ Aug 17 2023, 04:22 AM)
I like to measure from a chassis point and not the fender that is dependent on spring and shock
I have an aluminum cross member and like to use that flat spot on it as a repeatable measurement.
brant
jim_hoyland
Aug 19 2023, 07:59 PM
Any possibility of breaking the old bolt while backing it out ? Kinda rusty…
jim_hoyland
Sep 8 2023, 06:38 PM
Received the two PMB replacement bolts today. Is there anything Elsie to check while under the car ?
