I just reinstalled my engine after screw attaching my loose timing gear to the camshaft. I adjusted the valve clearance on the bench and then installed the distributor drive gear. Now in the car I get good spark, fuel flow and absolutely no starting or firing at all.
My question.
Is it possible that I installed the distributor drive gear 180° out of location? That would give me a spark plug firing at the top of each exhaust stroke and hence no running.
To check this I guess I would have to pull the valve cover on #1 side and check to be sure the #1 valves are both loose as TDC when the rotor is pointing away from the #1 spark plug wire.
Any thoughts or help would be appreciated.
