tat2dphreak
Aug 17 2005, 09:51 AM
ok, I replaced my coil before putting the engine back in... last night I was wiring up everything...
my old coil was clearly marked "+" and "-", the new blue coil is not... that I can see from the engine bay anyway.
I have the wiring diagram, and can see the green wire(from condensor) goes to one side and the 2 other wires go to the other side... but which coil side is for which wires?
I *think* I have it right, but want to double check before I start it up...
Aaron Cox
Aug 17 2005, 09:54 AM
Black and purple wire is your tach.... goes to the neg side.
Switched Current to coil is in a black and ??? wire..... and it goes to the +
tat2dphreak
Aug 17 2005, 01:14 PM
ok, is there an easy way to determine which side of the coil is which? if it's not labeled?
haynes shows 3 wires... the green on to the dizzy one one side, the other 2 on the other side...
mightyohm
Aug 17 2005, 01:15 PM
Pull it out, it's probably labeled somewhere.
tat2dphreak
Aug 17 2005, 01:19 PM
QUOTE (jkeyzer @ Aug 17 2005, 02:15 PM) |
Pull it out, it's probably labeled somewhere. |
yea, I was just now thinking that maybe the marks are hidden.
ArtechnikA
Aug 17 2005, 01:27 PM
they will definitely be labelled *somehow*
usually + and -
otherwise, it'll have the DIN codes - 15 is +
the other one (Terminal 1?) is minus...
tat2dphreak
Aug 17 2005, 01:33 PM
QUOTE (ArtechnikA @ Aug 17 2005, 02:27 PM) |
they will definitely be labelled *somehow* usually + and -
otherwise, it'll have the DIN codes - 15 is + the other one (Terminal 1?) is minus... |
ok, it IS labeled 15 and 1...
thanks! so, the green wire and black/??(not purple) go to the negative side?
ArtechnikA
Aug 17 2005, 01:38 PM
QUOTE (tat2dphreak @ Aug 17 2005, 03:33 PM) |
QUOTE (ArtechnikA @ Aug 17 2005, 02:27 PM) | it'll have the DIN codes - 15 is + the other one (Terminal 1?) is minus... |
thanks! so, the green wire and black/??(not purple) go to the negative side? |
i'm not getting sucked into the color thing, 'cause i can't see your car :-)
points and tach (which i thought should be black with violet tracer) connect to Terminal 1;
switched +12V connects to Terminal 15.
that's if you're using stock points.
if you're using some other kind of points replacement module or CD ignition, i'm not even gonna suggest...
Aaron Cox
Aug 17 2005, 01:47 PM
black/Purple TACH wire goes to - side....
Green wire from points goes to neg side...
3 - 2 = 1 wire left.... yup. whatever color it is...goes to the + side v
tat2dphreak
Aug 17 2005, 01:54 PM
ok, cool
yes, right now, it still has points, I'll sync the carbs with the 009 that's on there, then put in the 050 with a compufire... thanks!!
Aaron Cox
Aug 17 2005, 02:01 PM
QUOTE (tat2dphreak @ Aug 17 2005, 12:54 PM) |
ok, cool
yes, right now, it still has points, I'll sync the carbs with the 009 that's on there, then put in the 050 with a compufire... thanks!! |
Unilite
tat2dphreak
Aug 17 2005, 02:42 PM
QUOTE (Aaron Cox @ Aug 17 2005, 03:01 PM) |
QUOTE (tat2dphreak @ Aug 17 2005, 12:54 PM) | ok, cool
Unilite |
it's on the list, for when I get rich as shit!
