QUOTE(bdstone914 @ Aug 28 2023, 10:25 AM)
Only have the middle speed on the fan. Tested to motor and it runs full speed when powered directly at the motor. Pulled the control and cleaned the contacts.
I am wondering if the problem is in the terminal block at the fan. I am thinking there was a resistor in there.
Any ideas?
QUOTE(jim_hoyland @ Aug 28 2023, 01:09 PM)
I've wondered whether a more efficient blower could replace the original. The fresh airfaninmy '91 Volvo really puts out ?
does it blow a fuse if you leave it on low or high? mine did this and it turned out the previous owner had but the fuse block back in but crossed the wires so medium worked but high and low blew the fuse because it was shorting out.
regarding the resistor thats possible the resistor is gone or its just that the controller has warped and its not touching on low . to test this you can pull the wires and connect a different controller to see if thats the issue.
@jim_hoyland Jim, new fans with new motors are available and they really crank on high. the old fan bearings could be the issue and not letting it spin freely.
@bdstone914 If the resisitors are bad( you can test them) i think i have a second set of good ones in my box, let me know.
Phil
