If someone can confirm if the cable routing is correct please?
I had it off to replace and now not sure I have it routed correctly.
Should it go where the yellow arrow instead, but it was hard snaking it up that way, I think it takes bend or so, never was able to go the yellow arrow route.
It was worst earlier I had it wrapped around the alternator rubber boot.
It does operate when I heat the thermostat with heat gun and closes ok.
So maybe I got lucky I hope
Thanks,
