QUOTE(porscheteck914 @ Sep 7 2023, 09:46 AM)
Hello Gents . I have a problem hope you can help me . No 12v to fuel pump . Switch on . Thru these tests . Checked 25amp blue fuse on rear relay board and have 12v power on both sides of it . Did rotate relays around.-no change Checked to see if I had power going up to relays on relay board, with probe - have power to relays in at least one pin hole . I have NO 12v power on blk /red wire pin at 14 harness connector . Bad relay board ?- under at solder connection ???? Should I check continuity from which relay to blk /red 14 pin ? thank you for any help .
Paul 1973 1.7 fuel inj
Best 'go to' is to power your pump direct via a remote battery , if your pump is close to it use the cars battery.
Did you check the power supply relay in the relay board I had one go so the power direct to battery for pump indicated that , replaced it and all was good .
Something to go on with for starters but always expect more with these old cars,cheers.
