Another thing I ALWAYS do is to mark the balancer/flywheel with accurate TDC marks for all cylinders.
I'll verify if the original TDC mark is accurate by aligning that mark and doing a leak down test on cylinder #1 or the one opposite in the firing order.
I'm putting 100 psi of air pressure on the top of that piston and if it doesn't try to roll one direction or the other, I'm +/- a half a degree of TDC. The original mark is now proven good.
Leak downs are done all plugs out and transmission in neutral if still attached.
We want nothing stopping the engine from rotating on its own.
I'll remove the balancer and use a "dress tape" flexible tape measure and make marks via length in the correct positions. A four cylinder gets marks 180 degrees apart.
A six should get marks each 120 degrees, an 8 4 at 90, and so on.
This way seems to work better for me than plotting out degrees. I'll get a total diameter and divide it appropriately.
Finding a flexible tape that is metric makes this easier...
I'll make the initial marks via pencil on masking tape. Test those out the same way I checked the first. Once everything is good, I'll transfer the marks permanently to the balancer.
Leak down tests in chassis become far easier if a balancer/flywheel is prepped this way.
I don't have enough experience with true Porsche engines yet. I would sort of expect this job to already be done with the stock parts.
The two T4 balancers I've messed with DO NOT!
One of these puppies is ONLY marked at 7.5 degrees and doesn't even have an initial TDC mark.
Someone should have been "taken out behind the Barn" for forgetting this...
Ripping the transmission off to inspect what's going on INSIDE the bell housing is an integral part of "engine out" in my book!
