QUOTE(930cabman @ Sep 12 2023, 12:43 PM)
QUOTE(technicalninja @ Sep 11 2023, 01:10 PM)
mine will spine freely but doesn't have a bunch of wobble.
The bolt that holds it on the case is special and has a dedicated shank for the baby pully.
As far as I recall it's a shoulder bolt, with sealant on the threads on assembly
Shouldn't wobble too much
they all wobble and @ 50yrs old they bind up due wear in the roller bush which isn't a good thing for your engine ,not a DIY unless you have a lathe to fit a new bush,I won't use real worn out ones as I have a few spares so pick the best,even a worn roller will benefit by the use of a larger diameter cable such as a Shimano MTB real cheap to buy and stainless.
Such an important part of our engines and often done away with as many can't be bothered proper setup.
Click to view attachmentClick to view attachmentLower pic shows fully expanded after test with heatgun these cables work great and engine on stand tested ,cheers.
