QUOTE(technicalninja @ Sep 11 2023, 02:22 PM)
I once added 20+ grounds to a 79 Fiat X19. This might be the very worst car ever built regarding electrical BS.
Oh naive man.....
Let me introduce you to 1950s -1960s English cars and Lucas, the prince of darkness (because the electric headlights are always failing).
The Lucas motto: "Get home before dark."
Lucas is the patent holder for the short circuit.
Lucas - Inventor of the first intermittent wiper.
Lucas - Inventor of the self-dimming headlamp.
The three position Lucas switch - Dim, Flicker and Off.
The three position Lucas switch, alternate version - Off, Smoulder, Burn.
The Original Anti-Theft Device - Lucas Electrics.
>Lucas is an acronym for Loose Unsoldered Connections and Splices
Lucas systems actually uses AC current; it just has a random frequency.
"I have had a Lucas pacemaker for years and have never had any trou..."
If Lucas made guns, wars would not start.
A friend of mine told everybody he never had any electric problems with his Lucas equipment. Today he lives in the countryside, in a large manor with lots of friendly servants around him an an occasional ice cold shower...
Back in the 70's, Lucas decided to diversify its product line and began manufacturing vacuum cleaners. It was the only product they offered which did not suck.
Q: Why do the British drink warm beer? A: Because Lucas makes their refrigerators
Alexander Graham Bell invented the Telephone.Thomas Edison invented the Light Bulb. Joseph Lucas invented the Short Circuit.
Recommended procedure before taking on a repair of Lucas equipment: Check the position of the stars,kill a chicken and walk three times clockwise around your car chanting:" Oh mighty Prince of Darkness protect your unworthy servant.."
My experience with English cars was that they never figured out oil was a liquid, and they never figured out how to keep the smoke in the electrical components.
ELECTRICAL THEORY BY JOSEPH LUCAS - AKA Smoke Theory
Positive ground depends on proper circuit functioning, which is the transmission of negative ions by retention of the visible spectral manifestation known as "smoke".
Smoke is the thing that makes electrical circuits work. We know this to be true because every time one lets the smoke out of an electrical circuit, it stops working. This can be verified repeatedly through empirical testing.
For example, if one places a copper bar across the terminals of a battery, prodigious quantities of smoke are liberated and the battery shortly ceases to function. In addition, if one observes smoke escaping from an electrical component such as a Lucas voltage regulator, it will also be observed that the component no longer functions. The logic is elementary and inescapable!
The function of the wiring harness is to conduct the smoke from one device to another. When the wiring springs a leak and lets all the smoke out of the system, nothing works afterward.
Starter motors were considered unsuitable for British motorcycles for some time largely because they consumed large quantities of smoke, requiring very unsightly large wires.
It has been reported that Lucas electrical components are possibly more prone to electrical leakage than their Bosch, Japanese or American counterparts. Experts point out that this is because Lucas is British, and all things British leak. British engines leak oil, British shock absorbers, hydraulic forks and disk brake systems leak fluid, British tires leak air and British Intelligence leaks national defense secrets.
Therefore, it follows that British electrical systems must leak smoke. Once again, the logic is clear and inescapable.
In conclusion, the basic concept of transmission of electrical energy in the form of smoke provides a logical explanation of the mysteries of electrical components especially British units manufactured by Joseph Lucas, Ltd.
And remember: "A gentleman does not motor about after dark!"
Joseph Lucas: The Prince of Darkness" 1842-1903
