Hello,
I am going to drive out and look at a 1974 914 on Sunday. I've had a lot of conversations with the owner and I feel good enough about what I know to make the 4 hour round trip drive to look at the car. I'm looking to buy a solid 'driver' car that I can clean up and have fun with. I am not looking for a concurs or competitive 'survivor' show car. I'm in my 50's so not going to be hooning it around the streets, but would like to maybe try a beginner autocross event.
I hesitated to post this car here for fear of someone seeing it and buying it out from under me, that's a risk I'm going to have to take as I don't want to make a bad purchase. The car in question is a 1974 Zambezi Green 914 with the original 1.8 motor, trans, and stock fuel injection system in place. The car has been owned by the same owner since 1995. I like the car because it appears sound and mostly original. The only obvious changes appear to be the rear "PORSCHE" reflector between the tail lights and the 'snow shovel' looking front valance/spoiler. Regular maintenance but hasn't been driven much in the past 20 years. The owner has set their price at 20k and have listed it as 'firm'.
I'm assuming the front spoiler isn't a factory / OEM part, is that correct? That's one of the first things that would come off the car if I purchased it.
The interior appears stock which is another bonus for me. The dashboard isn't cut
The car has minimal surface rust in the front trunk (under the spare tire) and along the middle/center seam in the rear trunk.
There is some surface rust directly around / under the battery tray:
This is the one area that is causing me some concern:
I can't tell where that rust is located, but it appears to be more than just surface rust. Do you guys know where on the car this might be? Is this a reason to walk away from this car?
I believe this is directly to the side of the battery, not terrible?
I haven't been able to get a really 'good look' at there rockers/pans yet, but the owner did supply these two photos:
There is an area in one of the rockers that causes me some concern, which I'm assuming it under the battery area.
The car appears to be all original paint, or at least nothing stands out to tell me that there has been a complete repaint. I also saw in one of the photos that the door stay / door check strap is broken.
All gauges work, regularly maintained, 120k mile car.
My question is - based on what you're seeing is this a car I should even consider? I have owned many air cooled cars, several classics, and am not afraid of a pulling motors/transmissions/etc. (I'm assuming the motor is tired and will need refreshing)
Is 20k too much for a car in this condition?
Thank you
Ted P
Mogan Hill, CA.
