QUOTE(DennisV @ Sep 16 2023, 06:56 PM)
Got the bar and brackets out today. No glue. No reinforcement. I couldn't find any marks on the bar, but it was 15mm diameter.
Does the bottom hole serve any purpose in non-factory installs? It leads to a cavity in the frunk. In the videos I've watched, it doesn't seem to have anything on the inside to secure it.
Click to view attachmentwas 3-4 years ago i had mine apart. or at least as far apart to do the drop link bushings.
don't think we had it apart any further than that.
74 factory install sway bars from new.
i wasn't there the whole time my mechanic had the front end apart.
but every time i was there the stab bar was still in place in the fuel tank cavity.
the reinforcement plate is on the outside. (i'm pretty sure that is how it goes).
i have photos inside my fuel tank area from when i had it all apart but they are dark and blurry down in the area where the sway bar is. but i don't believe it was welded in on the inside of the tank recess going off memory).
welded in at factory. its got threaded holes.
the bolts don't have nuts from memory.
the holes in the reinforcement plate are threaded.
the bottom bolt just goes into the cavity.
don't think they ever changed it from start to finish of cars.
you can see the reinforcement plate in the photo despite undercoating.
Click to view attachment Click to view attachment the guys who sell post factory install kits seem to do all this by welding in a nut on the bottom hole of the external plate and use a half reinforcement plate on the inside with two bolts and a nut for the top two fittings. sort of like factory but not quite.
i think they end up with more reinforcing in the modern kits.
ian karr has a video on you tube. look it up. how to make use of the bottom hole as the modern install kits do.
if it was me - while you have it all apart i would just grab a modern kit and get it all in there properly. doesn't look like your car had the reinforcement plate installed.
which i feel is well worth putting it!!!
