NARP74
Sep 21 2023, 02:33 PM
Why would someone do this? Planning ahead for some rear suspension work and I find this. I am having a hard time thinking what they were trying to do. Am I screwed?
DennisV
Sep 21 2023, 02:49 PM
QUOTE(NARP74 @ Sep 21 2023, 01:33 PM)
I am guessing someone overtightened and it snapped.
The only thing I could think to do is weld a bolt to that center rod section so you have something to hold against.
Perhaps someone more clever than I am has a better suggestion.
GregAmy
Sep 21 2023, 02:58 PM
If you put a really good impact gun and 6-point impact socket on it it'll probably spin right off.
If the shaft spins and it doesn't come off, you can go underneath with vice grips on the shaft.
Clearly, you're planning to replace that?
NARP74
Sep 21 2023, 03:05 PM
It looks cut to me. The other side looks the same. No idea why.
I was not planning on replacing it until I took the hat off and saw it.
This changes my plans and cost quite a bit.
Superhawk996
Sep 21 2023, 03:12 PM
Like most things DAPO’s do, you’ll never figure out what they were trying to “fix”.
Just keep moving forward. Both suggestions above are good advice.
Mike9142.0
Sep 21 2023, 03:26 PM
The shaft on some rear shocks can be very long. My guess is that they were trimmed down so the the top was not damaged when stored is the trunk.
Sep 21 2023, 03:27 PM
QUOTE(GregAmy @ Sep 21 2023, 04:58 PM)
Yep. Rattle gun for the win.
Root_Werks
Sep 21 2023, 03:44 PM
Looks like a home made lock nut, ground down to "lock" the nut.
Yup, impact gun should zip that off pretty quick.
930cabman
Sep 21 2023, 04:00 PM
QUOTE(NARP74 @ Sep 21 2023, 02:33 PM)
Click to view attachmentNot screwed at all, when it's time to disassemble either impact or cut the nut off.
How many other "surprises" are from the prior DAPO
Geezer914
Sep 21 2023, 04:06 PM
What is that? Trying to figure where that is. Need an expanded picture.
burton73
Sep 21 2023, 04:17 PM
QUOTE(Geezer914 @ Sep 21 2023, 03:06 PM)
I take it that's the top of a shock tower? Just with the carpets near it, I confused me. Somebody either used a hacksaw, or somebody used a grinder. Try to get it off of there or leave it there until you're forced to get it off.
Bob B
NARP74
Sep 21 2023, 04:41 PM
Top of the rear shock tower. So I have a fully carpeted trunk and someone takes a sawzall to the shock rods that are sticking out of the top of the nut. Make it make sense.
In my case it is DA2PO. I am finding things from both previous owners, or at least the shops they used too.
I'll make a list sometime.
Root_Werks
Sep 21 2023, 05:19 PM
Don't forget there was a good number of years 914's were very affordable (cheap). Lots of Back-Yard-Bob's and their kids got a hold of 914's. Decades later, those "repairs" or "upgrades" need correcting.
NARP74
Sep 21 2023, 05:28 PM
This car has some high end upgrades. I don't agree with all of them, but someone wanted this to be a dream car, their dream, not mine. Some of the things I find just don't make sense.
bkrantz
Sep 21 2023, 07:32 PM
What brand rear shocks, and how old? They might be due for replacement anyway.
Gint
Sep 21 2023, 09:33 PM
I have an impact that will probably take those off without too much trouble.
targa72e
Sep 21 2023, 10:53 PM
No idea why thy did what they did. That said I use an impact on struts for removal (and sometimes instillation) so it would not really make a difference.
john
NARP74
Sep 22 2023, 08:02 AM
As a test I put a hand wrench on it and they both loosened up easily. Not sure if that is a good thing or a bad thing. They are Bilstein shocks, no idea how old they are or how many miles they have on them. I'll take a closer look this weekend for a date code and model info if they are on there.
