DaveB
Sep 21 2023, 07:54 PM
Like the title says...
Click to view attachmentThat is all that was left.
DaveB
infraredcalvin
Sep 21 2023, 08:05 PM
Ooof, that’s not going to come out easy… sharp edges on those cam bearings…
Superhawk996
Sep 21 2023, 08:48 PM
look around for them
Would be highly unusual for a dog to chew and swallow oddly shaped metal object like a cam bearing.
If they truly were swallowed I’d be concerned for the pooches health unless it’s the size if an Irish Wolfhound and can pass something like that.
DaveB
Sep 22 2023, 12:01 AM
QUOTE(Superhawk996 @ Sep 21 2023, 07:48 PM)
This is Monty. He is a 100lbs and a strong chewer. I took this picture after returning from the vet getting x-rays. Stomach and digestive system are clear. He knows he did something.
Click to view attachmentLessons learned to keep my work in the garage. I just got the crankshaft, crank and cam bearings and put them inside near the front door. Took the case in the garage, came back and realize the cam bearings were gone. We are now going through the entire house and yard.
DaveB
Geezer914
Sep 22 2023, 05:29 AM
Thankfully the dog is ok. I see pieces of the box, did he actually chew a bearing?
930cabman
Sep 22 2023, 09:10 AM
Man's best friend?
X-rays are clear?
Guilty as can be!!
100lbs, bet there's some force in those chompers?
How much are new cam bearings?
maybe need to spend more time with the beast
friethmiller
Sep 22 2023, 12:30 PM
Heck! By the time you sand the bite marks out of the bearings, your new cam will probably just be starting to spin free.
Assuming you find them first!
Shivers
Sep 22 2023, 12:41 PM
100 lbs, I’d be thankful he didn’t bury the crankshaft in the backyard.
worn
Sep 22 2023, 08:33 PM
QUOTE(friethmiller @ Sep 22 2023, 11:30 AM)
When I was growing up the dog would take my eye glasses from beside my bed and bury them in the carpet behind the sofa. I cannot see without glasses.
sixnotfour
Sep 22 2023, 08:40 PM
my 16 pound Dog...Charlie has Huge separation anxiety... He tore the metal off our back door and pulled all the foam insulation out,, outer tin all that's left... Not a scratch on him....We Learned he he can not be left alone... Now has a steel cage ... for alone time ..Its pretty bent up,, but he is adapting... Love Him..
sixnotfour
Sep 22 2023, 08:42 PM
triple post
sixnotfour
Sep 22 2023, 08:46 PM
technicalninja
Sep 23 2023, 08:17 AM
One of our keeshonds ate my wife's glasses.
Ate all of the plastic frames but didn't ingest the lenses.
Glasses were under "warranty" and they accepted the "hail damaged" looking lenses with hundreds of tiny teeth marks on them and gave us a new pair!
The tech at the eyewear shop said that was pretty common as the dog was after the salt in the frames.
Killer warranty!
BAD DOG!
Front yard mechanic
Sep 23 2023, 11:05 AM
I too have a dog that likes tools, bolts, car parts etc. every now and then I use my metal detector in the lawn to search
iankarr
Sep 23 2023, 11:26 AM
Good thing they don't make bearings the proper size anymore
