I removed my bumper and plastic headlight surround to see if there is a way to adjust the small piece in my photos. It appears there is no adjustment, just rubber grommets that hold both ends in place and they have some play. The one furthest to the right, touching driver side fender is loose so the gap between headlight cover is greater than the left attachment point. You can see second photo with light pressure pushing it back. Are these rubber grommets easy to change out? I did not want to pull one out until I get some insight.
