QUOTE(slapshot @ Sep 23 2023, 08:31 PM)
QUOTE(Spoke @ Sep 23 2023, 05:56 PM)
Did all 4 VRs give the same results? Exactly the same?
Does the GEN light come on when starting then go out for all driving?
With the engine running, lights on, measure the 3 voltages on the VR connector to chassis, not engine case.
D+ should be 14V
DF should hover 5-10V
D- should be zero volts
The charging system is quite simple but the components are buried in the car.
D+ and battery voltage and B+ should be identical.
Measure all to chassis, not engine case or battery neg.
All VRs react the same.
The charging light hasn't come on today even with the key on not running. I have seen it come on before.
Here's what I've got
Right after startup.
D+: 0V
DF: 0V
D-: 0V
B+: 12.6V
After a 1 minute drive parked at idle.
D+: 12.6V
DF: 7V
D-: 0V
B+: 13.7V
Parked reved @3000 RPMs
D+: 16V
DF: 3.1V
D-: 0V
B+: 15.9V
If I were a betting man, I’d bet alternator armature brushes are worn out or sticking based on the readings right after start up.
Would also explain the erratic readings as you drive.
The other weird reading is the 16v @ 3000 rpm with DF at 3.1v. Seems like the alternator is being full fielded but with very little voltage on DF. Could potentially be two issues with both a bad alternator and a sticky voltage regulator?
The more I look at the numbers - a sticking voltage regulator could also account for the numbers you see at at start up if contacts between D+ and DF are open. If they are stuck open, and DF isn’t even making it to the armature until then contacts rattle around / come unstuck and then the alternator can be bootstrapped to life.
I’d start by getting a good Bosch voltage regulator in to it. The fact that you have 4 of unknown quality and history isn’t helping convince me it’s not the voltage regulator based on your measurements.
914Sixer has a used Bosch solid state on F/S and sounds like a couple other NOS units on the way which will seem pricey but will be better than cobbled aftermarket units that don’t fit right.
Do you know what kind of regulators you’re currently using are - solid state transistor or the original mechanical solenoid style? Original mechanical regulators are sometimes repairable by cleaning the contacts between D+ and DF if you’re inclined to try to troubleshoot a mechanical regulator.
http://www.914world.com/bbs2/index.php?showtopic=367286Edit: just seeing this in context of initial readings after start
Yet another reason to stop screwing with aftermarket voltage regulators that don’t fit and may not work properly:
The more I look at your post(s) and the measurements - the more I’m leaning toward a bad voltage regulator regardless of what I said initially about armature brushes.
