NARP74
Sep 25 2023, 12:25 PM
Going to RRC2023 last week, I lost all my gauges just after leaving home. Pulled over to check things out and found a blown fuse. Blew a couple more before I figured out it was the left turn signal. Didn't use them for the rest of the weekend. I asked around and someone suggested I check the flasher or turn signal relay. I dropped the fuse panel and found this. Did someone swap my relays around?
Click to view attachment More in this thread to follow. I found lots of crap...
87m491
Sep 25 2023, 12:47 PM
They are not in the same location/order as mine, but I don't believe you can swap relays into the wrong receptacles/slots as the pin configurations are different for the Wehrle and the square units..
QUOTE(NARP74 @ Sep 25 2023, 10:25 AM)
NARP74
Sep 25 2023, 12:50 PM
I guess the bases could be swapped. I'll have to look at the connecting wires.
Dave_Darling
Sep 26 2023, 01:26 AM
The electrons don't care where the relays are. They just run along the wires to anything that happens to be there. The relay sockets can be moved around with some effort, and may not always have been put in the right place by Hans and Fritz at the factory.
Check the wire colors. If they're right, that's not your problem.
If the left turn signal is causing issues, the most likely causes are the turn signal housings front and rear, and the side marker light. Or the wires going to those.
--DD
914Sixer
Sep 26 2023, 05:36 AM
I see lots of NON STOCK wires in the background. Are they hooked up where they might cause a problem?
NARP74
Sep 26 2023, 10:06 AM
I have not even started looking at the non stock wiring, it is everywhere! Gonna be a real pain project.
NARP74
Sep 26 2023, 10:08 AM
It gets worse. Why was this cut and bypassed?
NARP74
What is this add on wire for?
jim_hoyland
Sep 26 2023, 10:50 AM
I had a similiar issue and is was:
“If the left turn signal is causing issues, the most likely causes are the turn signal housings front and rear, and the side marker light. Or the wires going to those.”
Good luck, fuse panels that have PO handiwork can be challenging
87m491
Sep 26 2023, 07:59 PM
That is a jumper wire to make the later 5 pin directionsl relay mimic the proper working of the original 4 pin relay.
QUOTE(NARP74 @ Sep 26 2023, 08:08 AM)
NARP74
Oct 14 2023, 02:35 PM
Swapped relays with others I had, no change. Found a light that was heating the reflector in the left rear, probably an intermittent wire short. Got that sorted, no change. Bought more fuses since I was running low again.
1. Is there a way to rig a resettable fuse or at least newer style fuses that I have a ton of for diagnosing this?
How do I dig into the turn signal switch or test it out to see what is going on in there?
Need to get this fixed so I can work on other issues and drive it a little before the snow flies.
NARP74
Nov 17 2023, 01:03 PM
Been working on this for a while now. I managed to not follow my usual practice of try one thing and verify it. I worked on several things at once and I am not sure what stopped the fuse blowing, but I have new issues that I have introduced.
Done so far;
Cleaned and lubed most of the front & rear contacts with appropriate products.
Took apart the rear light housing completely. I found an intermittent short between two wires on the trunk side. I think some luggage might have hit the wires while on the RRC 2023 trip. I could see evidence of heating in the outer shield from one of the lights.
I put in LED bulbs in all the external housings except the headlights.
I installed a new blinker relay from Spoke for the LEDs
So the new issues;
With no parking lights or headlight on;
The flashers work normal, 1 blink per second, dash indicator lights are bright
Left turn signal, fast blink, dash lights are dim
Right turn, the same
Parking lights on;
Flashers, lit but no blink, but the relay is clicking
The same for the left and right turn signal
Headlights on, same as with the parking lights on
The rear blinkers work properly in all scenarios
And
Parking lights turned on, dash indicator is lit
Headlights on, dash indicator is blank
Headlights on high, no hi beam indicator
I am sure there is a pattern here, what is it? Where do I look next?
NARP74
Nov 18 2023, 10:28 AM
Any ideas here???
Ishley
Nov 18 2023, 07:09 PM
I can’t say definitively… but I had gremlins in my turn signals
I ended up replacing the switch. That takes a little work to get it all changed out and working properly… but it fixed my issues.
campbellcj
Nov 19 2023, 07:32 AM
^^^ I just went thru the same thing - pulled my hair out going back over all the wiring to no avail, then talked to my mechanic who suggested it might be the actual switch and so I found one on the samba board and voila that was it. Not a cure-all but these switches are complicated mechanically and do wear or break after ~50 years.
NARP74
Nov 19 2023, 08:59 AM
Buying NOS or used old ones on Samba? Any good new sources? Do they still make them? I read a review of a cheap knockoff that sounded pretty bad. Who else has them?
Tbrown4x4
Nov 19 2023, 09:06 AM
I have had good luck finding intermittent shorts by replacing the fuse that is blowing with a sealed beam headlight wired to the fuse panel. When the short would blow the fuse, instead it lights the headlight. When the normal circuit load is flowing, the filament passes the current without lighting.
I hope I explained that well enough.
NARP74
Nov 19 2023, 09:23 AM
QUOTE(Tbrown4x4 @ Nov 19 2023, 08:06 AM)
Interesting idea. I have been looking for something creative like this so I can "see" what is going on.
I guess I would have to look for escaping smoke too since the headlight would take more than the amps rating of the fuse?
76-914
After you cleaned and replaced the bulbs you now have new symptoms? I would start by re-installing the old bulbs. If it still persists I would look into the turn signal assm. But before doing that I would remove those rogue wires from the fuse panel so that only the OEM wires remain. Then with the switch on (disconnect the + from your coil/points so you can leave the switch on for extended periods of time) see which fuses have 12v. After that do the same again but with the switch off. BTW, do the license plate light work?
NARP74
Nov 19 2023, 09:30 AM
QUOTE(76-914 @ Nov 19 2023, 08:23 AM)
The cleaning the contacts and connectors was done the same time I found an intermittent short in the rear bucket. I fixed that then I swapped in the LEDs.
All the rear lights function correctly now.
Just the front L&R turn signals are acting up.
I did not think it would be the switch since it would act the same for the front and rear. That leaves a wiring issue but I could be wrong. I will take apart the front turn signal buckets and inspect that wiring next. I cleaned the contacts but did not inspect the wiring behind.
The rogue wires is also an issue I need to get working on.
The license plate lights are one of the rogue issues, it is an LED lit frame spliced into the wiring in the back. Came that way. I will see if they work.
Spoke
Nov 19 2023, 09:57 AM
QUOTE(NARP74 @ Sep 25 2023, 01:25 PM)
Keep in mind that the flasher relay doesn't know which side turnsignals are on. If the flasher relay works with the right turnsignal then the flasher and the wires to it are likely ok.
I had a guy stop by with similar issues with his left running lights on his '86 911. He put in a 25A fuse and it wouldn't blow but it would get hot. Fronts were dim and the rears were out.
Luckily with the 911, separate wires from the front running lights and rear running lights terminate at the fuse. Pulled both wires off and the fuse didn't get hot. Put the front wire on only and the running light lit up as expected and fuse didn't get hot. Put the rear wire on only and the fuse got hot and no lights in the rear. Turns out he had a short to ground on the rear light bucket.
Moral of the story is you likely have a short in and around the front or rear light buckets. Maybe try removing the wire to the left turnsignal in the rear and front turnsignal as well. See if you blow fuses. If you don't blow the fuse, then the issue is the front or rear light bucket.
With both front and rear wires disconnected, remove both front and rear bulbs and check resistance to chassis for the front and rear buckets. Both should be infinite.
Tbrown4x4
Nov 19 2023, 06:31 PM
QUOTE(NARP74 @ Nov 19 2023, 08:23 AM)
No smoke. The bulb filament is now part of the circuit and replaces the fuse. This allows normal current flow until the circuit shorts to ground, the the high current from the short circuit that WOULD pop the fuse, merely lights the bulb. Sealed beam headlight or fog light only.
NARP74
Nov 20 2023, 09:27 AM
So the latest is that the fuse has stopped blowing, a couple of possible fixes for that one. An intermittent short in the trunk wiring for the tail light assembly, and I might have fried a relay. Will test the relay later. Got those both sorted.
I decided to put the incandescent bulbs back in the front turn signal housing and guess what? Things started working as I would expect. The LEDs are all still installed in the rear, incandescents up front. The blinkers function normally with no other lights on, 1 blink per second and both dash indicators are bright and flash at the same time. They also function correctly with parking lights and head lights on.
Looks like it might be something with the LED bulbs in that front position. I have no idea why they work in the rear but not the front. Same bulbs I think, just a different color in the back. I will swap and see what happens.
I can't be the only one trying to use LED bulbs for the front turn signals.
And here is one more oddity, with the LEDs in the front, no keys in the ignition, no lights on or anything running, if I hit the turn signals in either direction, there is enough current leakage to faintly light the LED bulbs, no blink, just a faint light. I get that they use less voltage but is that normal? Does that point to a turn signal switch issue?
And for the dial gauge indicators, are the arrows both supposed to light up no matter which way the turn signal is moved, or are they supposed to mirror the direction of the switch? I thought I had seen a previous discussion on this question.
VaccaRabite
Nov 20 2023, 10:57 AM
Its the switch. You need a switch that is designed for LED bulbs. The LED bulbs draw too little power for the old switch to realize they are turned on, causing unexplained issues. There is a modern switch you can put it that might cure your issues.
I have full LEDs. On my car the switch won't blink the indicator on the dashboard. I have the new switch to install (and have had it for years now) but I have not gotten around to installing it.
Remember that LEDs are also Diodes. Incandescent bulbs are not, and don't care how they are wired. If there are crossed wires in the front somewhere the LEDs won't work.
Zach
NARP74
Nov 20 2023, 01:58 PM
I have talked to a few people and verified on another car, that the lights do turn on when not running and no keys in the car. Just move the turn signal and running lights and warts if you have them illuminate. I never knew this.
campbellcj
Nov 20 2023, 05:24 PM
QUOTE(NARP74 @ Nov 19 2023, 07:59 AM)
Someone mentioned that a 75/76 Mk 1 VW Rabbit/Golf switch was compatible and I got a NOS one for $80 or so which worked perfectly.
Prior to changing the switch the specific symptom I had was that the hazards blinked and worked normally, the parking lights also were fine, and the Euro 'park mode' of the turn signal also worked fine, however in actual turn signal mode the lights would not blink.
Spoke
Nov 20 2023, 09:57 PM
QUOTE(NARP74 @ Nov 20 2023, 10:27 AM)
@NARP74 What year is your car? I've heard that for some early? '74 cars with single L/R indicator, some '73 tachs were used and both L and R were wired together. Have you seen yours before light separately? When going to LED turnsignals with the OEM flasher, both L and R indicators will light together and there's a chance that the opposite side turnsignal will light gently.
If using LEDs on all turnsignals, you need an LED-compatible flasher like EP26 with the K2 pin modded to ground.
NARP74
Nov 21 2023, 09:16 AM
Car is a 74, but... it has a Gates dash conversion and I don't know anything about the gauges, if they are 911 or 914, could be some of each. I will have to take one or two out soon to answer some other questions anyway. I don't recall if the indicators ever worked separately or not.
I do have the EP26 that I purchased from you, 2 actually. I was going to do the LED upgrade on 2 cars if the first one went well. So much for that. I am going to put the 2nd relay in just for another test comparison.
@Spoke do you do any mods to the EP26 or are they all the same?
It looks like 3 options at this point;
The switch, looking for a spare to test
The relay, easy to test since I have another
The LED bulbs, I could try another set
I have seen info on adding a load resister to non LED circuits. Is that in play here?
Spoke
Nov 21 2023, 11:07 AM
QUOTE(NARP74 @ Nov 21 2023, 10:16 AM)
@NARP74 Sounds like you do have funky things going on with your lights. If LEDs didn't work in the front but incandescents do, then it might mean the ground is not making contact in the front. Check to see if both filaments light up with turnsignals. Do the running lights work with bulbs and LEDs?
EP26 from me are modded for early tachs with separate L and R indicators and for later tachs with a single R/L indicator. The EP26 mod has to match the tach type.
The load resistor thing is for cars using LEDs with OEM flasher relays designed for incandescent bulbs. Not needed on your 914. You should be fine with EP26 as it can drive LEDs or incandescents.
Spoke
Nov 21 2023, 11:23 AM
QUOTE(NARP74 @ Sep 26 2023, 11:08 AM)
Click to view attachmentThe Blue/White wire goes to K2 which powers the common connection of the tach indicators. This is set up like OEM and IF your car has separate L and R wires going to the indicators, this wire needs to be reconnected to the socket. IF you car is set up to have both indicators flash together, then the cut is ok.
You need to pop out the tach and see where the wires to the indicators come from. One wire from each should connect together then to the Blue/White wire. If the other 2 are connected together, then your car is set up for both flashing together.
majkos1
Nov 21 2023, 04:46 PM
Don't you have Five gauges ?
That's a Getty set-up
NARP74
Nov 22 2023, 09:14 AM
QUOTE(majkos1 @ Nov 21 2023, 03:46 PM)
Yes I do and yes it is. I'll start another thread on the gauge, cut blue wire, turn signal issue. I want to finish the blinkers actually working issue first.
87m491
Nov 22 2023, 03:08 PM
QUOTE(NARP74 @ Nov 20 2023, 07:27 AM)
Nope just went nearly 100% LED (no headlights yet) in my 74 a few months ago. I had a problem with cheap dual "filament" brake tail light bulbs but fixed with better bulbs. The fronts worked right off. Is your/did you make your flasher relay LED compatible?
NARP74
Nov 22 2023, 03:40 PM
QUOTE(87m491 @ Nov 22 2023, 02:08 PM)
I bought the flasher relay from Spoke, all ready to go, plug and play. I do have 2 of them. I will test the 2nd in the next day or two.
