joeav8tor
Aug 18 2005, 10:23 AM
mystery solved...got a new speedo angle drive seal on the way but the tranny bolt hole appears to be stripped...that sucks...options please...hopefully I dont have to drop the motor again this soon. If it is going to be a major nut roll then my driving season has come to an end because I am going overseas with the military.
thanks for the help
Joe
SLITS
Aug 18 2005, 10:26 AM
timesert / helicoil
it can be done from the outside under the car.....it just locks the speedo housing / driveshaft in place.
joeav8tor
Aug 18 2005, 08:04 PM
has anyone ever used an insert? and how does it work?
thanks
Joe
Joe Bob
Aug 18 2005, 08:05 PM
Thin coil that is screwed into a hole..the coil provides grip for the bolt.
bondo
Aug 18 2005, 08:41 PM
I think that hole may be helicoiled from the factory.. They strip out when people don't line up the hole and try to tighten the bolt. The o-ring is past that, so if the threads in the tailcover are mangled beyond repair you can do whatever you like to hold the angle drive in. (nylon ties, etc.) You could also tap it for a bigger bolt and make your own pin-ended bolt.
bd1308
Aug 18 2005, 08:48 PM
i think tapping would be easiest
dremel a point on the end of a bolt
and you're done
Mueller
Aug 18 2005, 08:50 PM
not sure what size it is, but if you figure it out, post a WTB (want to borrow) ad for the helicoil kit, I have one in 8mm and 10mm I think (with coils) if you cannot find someone local, pay for shipping (both ways) and help yourself to a helicoil on me
Bleyseng
Aug 18 2005, 10:36 PM
all the trannys I have (four) are helicoiled. must have been standard practice back in the day? Capt, Captain? Is Capt Krusty in the house?
p914
Aug 18 2005, 11:51 PM
Helicoil first, I actually used a bit of superglue to keep mine in and it worked for over a year and a half! Then I put the helicoil in.
joeav8tor
Aug 19 2005, 04:00 AM
thanks guys!
Joe
DipShit
Aug 19 2005, 02:48 PM
Heli-Coil worked great for me when I was dumb enough to over-torque my oil screen plate on the 911.
TravisNeff
Aug 19 2005, 07:26 PM
The tranny I resealed already had a helicoil in it as well. Must be a common problem or something from the factory
scotty b
Aug 19 2005, 08:01 PM
Take a coarse file and file the threads off of the bolt, then mix up about a half a tube of JB Weld, roll the bolt around in the pile'o weld, put any excess JB on the previously threaded portion and cram the whole lot back in the case. Twist slighly to ensure a good mashing and let dry for a few hours. In the meantime go buy a case of Corona and consume as quickly as possible then run around the yard in a ever widening concentric circle while staring up at the sky...hold it down
.......hold it down.
.....hold it down
................now
How's the tranny doin? Don't care any more do you?
