Working with a tech but not familiar with 914. Car is 74, e flashers work but not turn signals. Trying to check switch ……have a spare. Can switch be accessed without removing steering wheel..? Any guidance appreciated. Thanks
emerygt350
Oct 2 2023, 03:33 PM
No, but removing the wheel and replacing the whole turn signal assembly is super easy.
sixaddict
Oct 2 2023, 05:39 PM
Thanks….. Saves me from going the wrong direction.
sixaddict
Oct 3 2023, 06:56 AM
One more question……does lower dash pad need to be removed to change turn signal switch. It’s been a long time since I have had one out…….
windforfun
Oct 3 2023, 06:20 PM
Yes. I had to in order to get to the electrical connector. And don't tighten up the mounting screws. Let the assembly "float" in the column.
sixaddict
Oct 3 2023, 08:44 PM
Thanks
sixaddict
Oct 5 2023, 11:57 AM
So we have turn signals….but a twist to problem. My neighbor is retired Porsche tech. Some help from Dave D on Bird site…. He kept trouble shooting and made test light work ……plug at end of steering column was disconnected…….and hanging loose. No clue how ! Try removing lower dash pad with cage in car. Everything working. Thanks all….
