When I dropped the motor of my '73, I forgot to pull the harness, and all the wires pulled out of the harness. Using a Tech Manual, I was able to figure out where 6 of the 7 wires reconnect (the car was converted from fuel ignition to carbs), but can't figure out where the solid black wire goes. The harness has 11 'posts'. I have not 'traced' any of the wires to see where they go (lights, etc.). I also have a heavier gauge red wire with white stripe and a typical female connector which pulled out. Can anyone help to figure where these 2 wires connect. I also have a few wires that appear to belong in the relay/fuse box which were cut and capped (they were that way when I bought the car). It ran fine, and everything necessary electrically worked. I am a mechanical moron, but was able to put in my new motor and start it. I had to drop it again due to an oil cooler leak (that's when the wires pulled out of the harness).
I am new on this site, so hopefully I can figure out how to find any responses to this post. BTW - this is my 3rd 914. I love these cars as much as any of you out there. Bought my first ('73) in '74. It was a black beauty.
Thank you in advance for any of you that help.
