Using this cheap LCR
https://www.amazon.com/gp/product/B07CYSV5L...e=UTF8&th=1
I have been tuning my MPS. Finally got it, had some real issues getting it rich in the right spots for my 2056 build. I doubt I had it 'right' for my worn out old rings and guides. Anyway. For the past couple weeks I have been poking at it. Taking measurements, graphing the results of little tweaks.
Today I got it pretty darn close. The top line in the graph is the one I am running currently. It was not easy to get it there. Each adjustment affects the others. It is still a little rich at the top and a little rich at the bottom, but cruise is where I was having the issues. Just took a long interstate drive and it no longer goes lean anywhere.
The first graph shows the range from leanest most linear to the final. You can see how much the lines slope can be played with. Not much.
I didn't take full measurements on the initial but it wasn't good. To get it to run without going super lean at cruise I had to put a 50 ohm resistor (in addition to the 73 270ohm CHT resistor) on it.
Suprising to me is how little change was required to make that spot 'prefect'. Also, the affect on WOT (low inhg) was small. A little richer than before but not much. Anyway, here are the data points for those of you that may need to go here someday with a cheap LCR. I am at 850 feet above sea level, but I don't think trying to get the actual values is worth much. I think it is more about the slope.
