MattR
Aug 18 2005, 02:56 PM
Question for the type 4 masters out there:
My new 2056 is leaky (~1 qt in 10 mins from the oil cooler seals). I thought it was the seals, so I took those out and tried to seat them properly dozens of times with no luck. Now Im thinking its an oil pressure thing. I plug in my electrical VDO gauge and it pegs it (past 80 psi). I dont THINK my oil pressure relief pistons are stuck. I pulled the plugs and they slid freely in their bores. Are there any other suggestions for too much oil pressure?
Im running a shadeck 30mm t1 pump and ive drilled and tapped all my oil galley plugs and cleaned the galleys.
Ideas?
Twystd1
Aug 18 2005, 03:04 PM
BUMP....!!!!!
Twystd1
Aaron Cox
Aug 18 2005, 03:08 PM
point of reference: i have a similar high flow pump... cold oil PSI at idle is about the same....but my cooler seals dont leak
and i have non stuck replacement bleed off pistons....
AA
MattR
Aug 18 2005, 04:52 PM
Nevermind...
I hooked up a mechanical gauge and got 60 psi at idle and near 75 at revs. Back to being confused
SLITS
Aug 18 2005, 05:10 PM
You might start looking for a hairline crack in the cooler / case.
Might be useful to take it off and have it pressure tested
or
obtain another known good one and refit.
Aaron Cox
Aug 19 2005, 12:10 AM
howd it go today matt?
you and clayton knock it out???
