BE PATIENT!! use aerokroil or pbblaster. last time i used a combo of the 2. spray the nuts down well and let it work, i hosed them down for 2 days. spray again. if any threads are showing, get up in there and clean them as best you can. spray again. the nuts themselves don't require a lot of torque to tighten the he's down. if you feel like you're reefing on them, trouble is not far behind. lightly, LIGHTLY!!, tapping on the nut/stud with a punch and small, SMALL, hammer can help loosen the rust bond and vibrate the penetrant in. spray again
. a slight working the nut back and forth as you remove them can help. spray again! hopefully, the worst it will be is, the stud turns out with the nut. spray again! if the clearence between the he and nut is too tight for your 3/8" drive socket, go to a 1/4" drive. when you get new nuts, get these 12mm.
k
