Selling my 1972 914. Runs and drives great. Fort Lauderdale Fl. Lots of new parts and pieces. I'm moving very soon and need to downsize the vehicle collection.
Here's a particle list , more details in the folder link, if it works. My email is jcrtd@icloud.com
I have pictures and video of every inch of car.
https://www.icloud.com/iclouddrive/028cyzbH...DAkDng#914_info
Work completed , new parts , etc.
New engine 2258CC. : All new parts from European MotorWorks
Engined assembled by European MotorWorks
MegaSquirt Engine management.
New floor pans installed by PO.
Master cylinder , 914 rubber .
Rebuilt brake calipers, all 4 corners . PMB Performance
T-4 914 CASE
DECK CASE T-1 / T-4
ALIGN BORE T-4 CASE
DRILL TAP OIL GALLEY HOLES T-4/T-1 3/8" SOCKET PLUG ZINC 96MM CYL. ONLY
96MM PISTON 80MM STROKE 22MM PIN K/B 2.0H-BEAMRODSSETOF4 5.325" 22MM PIN
5/16" ROD BOLT
ASSEMBLY LUBE
MAIN BEARING SET .050 X STD X 1.00 THRUST T-4
2.0 ROD BRGS. STD
T-4 STD CAM BRGS.
T-4 E CAM 280 DUR. X .435" LIFT T-4 ALUMINUM CAM GEAR -3 CAM BOLTS
T-4 SOLID LIFTER
CHROMOLY CUT TO FIT PUSHROD 3/8" .035 WALL THICKNESS PUSHROD LENGTH MEASURING TOOL DIST. DRIVE GEAR BRASS TIMING GEAR
LOCK RING CRANKSHAFT
SPACER
914 215MM FLYWHEEL German not Chinese
Heads:
New European MotorWorks head castings.
NEW BARE 2.0 HEAD
INSTALL GUIDES PER HEAD INSTALL VALVE SEAT EACH SURFACE HEAD EACH 3 ANGLE VALVE JOB PER HEAD CUT HEADS DUAL SPRINGS EACH
PORT & POLISH PR.
46MM T-4 VALVE Stainless Steal 38MM T-4 VALVE Stainless Steal 46MM INTAKE VALVE SEAT 38MM EXHAUST SEATS
PORSCHE 2.0 8MM GUIDE STD DUAL SPRING H/D SET 8 CHROMOLY RETAINER SET 8 CNC HEAT- TREATED VALVE KEEPERS,SE
MegaSquirt Engine Management: Parts from The Dub Shop
MegaSquirt 3 computer Crank trigger wheel Coil pack
New injectors
Idle control valve
Other items:
New clutch, pressure plate and German flywheel. New tires.
New fluid in rear end and transmission.
Side shift transmission, works fine.
Interior carpet. German loop from 914 rubber. New fuel line under gas tank.
New fuel pump and regulator.
