914 with fresh 1.8 and 123 distributor. Idle jets were swapped around , no change. only seems to happen on #4. Notice the pooof in the barrel when it pops?
Kevin
Superhawk996
Oct 26 2023, 10:24 AM
Timing and/or valve adjustment
rhodyguy
Oct 26 2023, 10:53 AM
Use 1 idle speed adj screw to raise the idle a bit and remeasure the flow across all 4 Venturi. The other ISAS should be off the stop. Then report back with #s. At what rpm does the ‘sneeze’ cease?. What rpm is your idle set at?
brant
Oct 26 2023, 03:42 PM
I also have seen this if that cylinder is down on compression Do you have recent compression testing numbers?
nivekdodge
Oct 26 2023, 05:59 PM
QUOTE(brant @ Oct 26 2023, 05:42 PM)
103 -116
Kevin
nivekdodge
Oct 26 2023, 06:00 PM
QUOTE(rhodyguy @ Oct 26 2023, 12:53 PM)
idle around 900 airflow at 6
Kevin
