1974 – Red 914 Porsche 2.0 liter – 95,310 miles odometer + ~2500 miles since 02/07
PRICE REDUCED TO 12KSet up as a HPDE Track Car by RAC, previously was an Autocross Car. Currently street legal w/VA license & reg. Garage kept. Prepared and maintained as a Track Car by Stuttgart Porsche of Williamsburg VA. Owned since 5/89, did some autocross in early 90’s. Went on Track 2/06. End of Track running ~ 12/06. Italics below represent upgrades since I owned it. Only breakdown on track was for a broken half shaft at VIR.
Vehicle Modifications
1. Suspension - lowered and stiffened by prior owner. Adj front swaybar. Adj rear swaybar (off car for track events)
2. Brakes - Upgraded to 19mm master cylinder. SS Braided lines. Using stock PBR Pads and stock rotors. Used ceramic pads on the track.
3. Seat Belts - 5 point camlock seat belts installed for driver and passenger replacing 5 way lever latch belts. New 3-way belt installed once no longer used on track.
4. Steering - updated to turbo tie rods.
5. Right side mirror was added.
6. Underbody tie-downs added front (2) and rear (2). Needed for trailering or being pulled off track.
7. Door panels redone as speakers were cut into doors and panels and backing board was worn-out.
Engine & transmission
8. Engine blueprinted and balanced by prev owner. Runs to 6000rpm w/o issue – redline is 5600.
9. Fuel Pump – Relocated to front of vehicle. Avoids engine heat issues.
10. Rain baffles were removed to allow more air to engine by prior owner.
11. Engine thermostatic heating baffles removed as were inclined to stick at high summer temps.
12. K&N cylinder type air filter fitted. OEM parts saved.
13. Auto Atlanta high rpm kit added. Diff head sensor provides diff reading to computer at high rpm and diff fuel regulator feeds more fuel to engine and providing noticeable increase in HP at high rpms.
14. Deep oil sump added (for oil pick-up during hard cornering)
15. Heavy duty oil pump added by prior owner.
16. Replaced motor and transmission mounts. Transmission mounts are now solid type.
17. Heavy duty clutch, pressure plate & new flywheel and clutch cable
18. Rev limiting rotor added – 5600 rpm for normal driving.
Tire Extras
19. 6 extra original Fuchs Rims plus 8 tire caps
Issues
20. Transmission synchros for 1st and reverse worn when bought.
21. Tach is off slightly 5600rpm is really 6000rpm.
22. Wipers have only high speed and don’t park.
23. Back window rattles.
24. Needs paint badly – it’s a track car and slid through a gravel trap once. It was a Lime Green car originally and was stripped and painted red. Also needs a little bondo work at cowl & windshield weld, Rubber joint had been removed and metal had been welded for stiffness by prior owner.
Changes
25. Radio not connected. Speakers removed from under dash. Parts saved.
26. Clock replaced by oil pressure gauge. Clock saved.
27. Doors redone w/ no pockets & no speakers. OEM door storage compartments saved.
28. Trunks - Pads removed from hood & trunk. Parts saved.
TRACK CAR COMMENTS – Drives extremely well, handles superbly. Perfect for HDPE and learning to drive at the limit. Excellent steering and throttle modulation. Using soft compound racing tires Yokohamas Advan AO32R 205/50-VR15, the brakes can be locked up only at max braking if you have strong legs. Sometimes fronts lock up, sometimes rear depending on track conditions. Braking wear very even, rear pads have life 1.5 times that of front. Car weight 2050#. Dyno 1/07 = 90hp at rear wheels. Good compression and leak down tests in 10/06.
OTHER COMMENTS - NO OIL LEAKS & NO RUST. Battery box is in good shape. No accidents I am aware of however there is “supposedly” some bondo high on the front of the rear fender on the driver’s side at a small dent.
1974 PORSCHE MAJOR REPAIR HISTORY Updated 06/15/2023
History before RAC ownership was transferred from Owner’s Manual & other Documents.
R A Costello has two notebooks detailing ALL REPAIRS and all purchases during his ownership
00,000 11/27/73 Delivered to unknown purchaser in CA
Unknown 01/24/75 Sold to Johnny Humphreys & Rosemary Rodd in CA-Rosemary ran Autocross
48,006 06/78 Rebuilt Engine
Unknown At some point Rosemary took sole ownership of car & moved to Richmond VA
54,200 10/78 New swaybar & replaced front shocks.
59,000 02/23/79 New Brake Master Cylinder 17mm
72,222 Rebuild Engine
84,895 Rebuild Engine-Bored (1mm to 2013.6cc from 1971cc) Blueprinted & balanced. Trans rebuilt, new muffler installed.
91,703 05/26/87 Sold to RAC – Purchased in Richmond VA from Rosemary Rodd – she still running Autocross. RAC altered car to Road Track Car
93,010 New Clutch cable & battery
93,982 12/05 Freshened engine (fuel & vaccuum lines) & trans. New clutch & flywheel. Sump kit added, new brakes/rotors, turbo tie rod, rear swaybar, K&N air cleaner
02/06 Started running car on track at NASA events (HPDE – high preform driving exp)
08/06 Broke driverside halfshaft at VIR. Used halfshaft, & high rpm kit installed
09/13/06 Master cylinder upgraded to 19mm. Rev limiter 5800 rpm installed.
10/08/06 Rebuilt shifter linkage. Compression & leakdown test.
11/06 Stopped running car on track at NASA events (HPDE – high preform driving exp)
01/24/07 Car put on dyno. Tack was off 300-400rpm however as car was ALWAYS run to Redline in the lower gears on track with no harm the dyno operator went
to Redline on the tach. Rev limiter pulled for dyno runs.
95,310 02/07/07 The odometer stopped working again. Could not be repaired but needed replacement of entire 3 gauge dash with new used dash. Did not do.
04/10/07 5 Way Seat Belts replaced with 3 way over the shoulder seat belts
01/29/10 Front shocks replaced with Koni adjustable Performance Shocks
95,310 06/15/23 Car in storage facility or garage since 1991. Driven occasionally & had regular State inspections and maintenance as needed. Probably driven about 125 miles per year.
The entire time the vehicle had been owned by RAC it has been maintained by owner Robert Lynch & mechanic Michael Owen of Stuttgart Service of Williamsburg, 243 Ewell Road, Williamsburg, VA 23188. 757-565-4700. www.stuttgartservice.com. Robert Lynch was the only local person I ever found who was truly capable of working on 914’s. He wasn’t cheap but he was good – my 12/05 bill for prep to go on the racetrack was $17k. The car was off the track in the grass once and through a gravel trap once and also did a 360 spin on a wet pavement once (but stayed on the pavement). Starting in 2007, after I stopped driving it on the track state inspections were generally performed by Howard Motors of Williamsburg. I bought a track prepared 88 Camaro on 01/03/07 and the Porsche never saw the track again.
I have the full maintenance history while I owned the car in 2 notebooks.
1974 PORSCHE - following items included in SALE 06/15/2023
1. 1974 Porsche VIN 4742904935 – Originally color - factory lime green. Very thorough paint job (car stripped/dismantled before painting. Red paint job was done sometime before 1987.
2. 4 Racing tires (old) and 6 additional rims and 8 rim wheel caps.
3. Box of misc books including Owner Manual and Rosemary Rodd’s “Clymer Porsche Service / Repair Manual 914 Series / 1970-1975” with numerous notes. Notebooks with R A Costello’s history of service & expenses. Numerous other books.
4. Jack & jack handle & round plate for insertion in jack port to be used with standard floor jack.
5. New ”never installed” set of light tan carpets for the car from Auto-Atlanta.
6. Original worn Carpets from front & rear trunks.
7. Tan Technalon Car cover and black front end bra.
8. Fiberglass front valance
9. Two-piece rubber and plastic front air dam
10. Engine Parts - Used 2.0 injector, extra deep oil sump kit, extra Bosch injector trigger points. Extra K&N Filter, 3 extra plug sets, rotor, condenser, distributor cap and lots of other parts. Oil Thermometer dipstick. Set of new engine hoses.
11. Rear swaybar.
12. Brakes - front brake dust seal set, extra pads front & rear.
13. Body parts - door latch, driver side rear light lens (used), sun visors & assorted engine grill letters.
14. Box of original stock parts removed – does not include any of the drainage and rain baffles around the engine compartment as they were gone when I bought the car in 1984. Includes radio speakers, original clock and original 3 hole console panel.
15. 2 sets of 5 way racing belts and installation hardware. Latch-type were on car for Autocross & newer cam-type release belts were installed for track events. Eventually removed once the car was off the track and standard 3 point belts after-market seat belts installed.
Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment[attachmentid=891
992]Click to view attachmentClick to view attachmentClick to view attachment[attachmentid
=891996]Click to view attachmentClick to view attachmentClick to view attachment
