The two Type 4 engines and two 914 gearboxes from my Tangerine Racing F Production car are for sale.
A-spec engine, asking $7500
B-spec engine, asking $6500
Gearbox with LSD, asking $3500 *Sold*
Open diff gearbox, asking $2500 *Sold*
A Spec (180 hp) – Engine Needs to be rebuilt, has low compression.
· 94mm Nickies Cylinders with Custom JE Pistons
· Align Bored Crankase with Custom oiling mods
· Custom Lightened Rocker Arms with 911 Swivel Foot Adjusters
· Chrome Moly Pushrods
· Silicon Nitride Lifters
· Elgin 312 degree duration Camshaft (7806-20)
· 7mm Stemmed Stainless Steel Valves with Beehive Springs & Titanium Retainers
· Cylinder Heads with fully Ported intake & exhaust, cc'd for 12:1 Compression
· Balanced 66mm Crankshaft
· Carillo Rods
· Lightened Flywheel with 911-S Clutch disc & Aluminum Pressure Plate
· Custom Dry Sump Oiling Modifications include 2 Stage Schadek Oil Pump, Belt Driven Moroso 2 Stage Oil Pump Scavenges the Valve Covers
· Belt Driven Horizontal Fan Cooling System with Aluminum Shroud
· Weber 40 IDF Carburetors with custom manifolds - Highly Modified
· Mallory Unilite Distributor & CD Ignition Box with adj. rev limiter
B Spec (150 hp) - Low operating hours
· Align Bored Crankcase with oiling mods
· Elgin 304 Degree duration Camshaft (7606-20)
· 8mm Stemmed Stainless Valves with HD Single Valve Springs & Titanium retainers
· Cylinder Heads with fully Ported Intake & Exhaust, cc'd for 11:1 compression
· Carillo Rods
· Lightened Flywheel with Stock PP & 6 spring clutch disc
· Weber 40 IDF Carburetors with custom manifolds – Modified
Short Box for A Spec Engine *Sold*
· ZF Limited Slip Differential (80%)
· Custom Input Shaft with welded second gear
· 911 Output Flanges
· Gear Ratios: A, I, M, Q, W
· Swepco 201
Long Box for Pocono & B Spec Engine *Sold*
· Open diff
· Gear Ratios: A, F, Ka, Q, X
· Swepco 201
