[quote name='porschetub' date='Nov 4 2023, 07:10 AM' post='3111085']
[quote name='cassmcentee' post='3110958' date='Nov 3 2023, 06:08 AM']
Click to view attachment[/quote]
This is how I did it with a generic linkage from China (Aliexpress) which I upgraded somewhat, I messed around and got the geometry of the rods as close to operation in the horizontal open and closed position on the throttle arms it makes everything line up and because I used short inlet manifolds I had to factor that in also.
Rear mount this linkage and centred @ case join so pretty much even rods end to end ,fitted CB performance rod ends as were better than what came with the kit , they had a bit more play in them than I liked but were ok.
Checked throttle openings @ stops and came out even,a lot of work but turned out great.
Pics added ;
Click to view attachmentClick to view attachment Cheers.
