Copied from another thread
http://www.914world.com/bbs2/index.php?sho...61192&st=20This is a way to pre-prime any engine...
I haven't had to try this on a T4 but on the very worst designed oiling system in the history of internal combustion engines this works GREAT!
Engine in question is the early "odd fire" 231 ci V6 that GM use in a bunch of stuff from the late 70s though the mid 80s.
You could change the oil and loose the "pump prime" on these.
Lots of engines were destroyed by poorly done oil changes...
Remove either the oil filter OR the oil pressure sender and apply oil under pressure into the engine.
We would remove the sender and install a hose we made up to a facet fuel pump (square box style). The inlet side of the fuel pump would get a hose that we'd put into a quart of oil. We would apply 4psi oil to the engine and then turn it backwards for 360 degrees which would prime the pump.
This was the only way that worked every single time.
Sort of a PIA but when nothing else would work this method did.
After the "set up" was created the time it required to do this was under 5 minutes.
I ALWAYS pre-pressurize a fresh motor in this manner after a build. Normally it's still on the engine stand out of the car.
After install I kill fuel/spark and rotate it with the starter motor until the gauge sees pressure.
If I can I fill oil filters before install during a normal oil change. Some designed do not allow this.
