QUOTE(Jim C @ Nov 7 2023, 03:23 AM)
Thermostat failed. Have to wait for a new one.
Click to view attachmentThats most likely your high temp problem as the thermostat hasn't failed in the fully open position , normally they do, when you replace it don't set it up with a tight cable ,they need to have some slack so the unit isn't strained when compressed (cold ) .
Set up and test with heat gun once you are happy it is right and flaps are fully open when the bellows is fully expanded you will be fine .
Click to view attachmentClick to view attachmentYes the bike cable is the way to go as besides the fact the rollers flog out on the center bush the vee in the base of pulley wears out also and the stock cable can jam for that reason,as the bike cable is a larger diameter and finds a better area to rotate on.
Many who don't run a thermostat don't understand WHY they are there , the cost new is up there so often avoided ,shame really as its a vital in good engine life .
There is a solution I found using a T1 unit ,they open 5 C earlier but don't see an issue there as better than not having one ,plenty on the Samba used for little money compared to new type 4 ones.
Cheers.
Very helpful. Thanks!
