QUOTE(JMTaxter @ Nov 11 2023, 09:18 AM)
Where does the AAR lead typically connect?
The downstream side of the fuel pump circuit, parallel (or maybe connected to?) the ECU circuit T12-12 (hot when fuel pump relay is energized). It's a 0.75mm supply wire.
Is there any reason I can't get the 12V from the No. 15 side of the ignition coil?
It's a higher-amp circuit, running a bimetallic element. That answer depends on if you think the coil circuit can handle the extra load...all the time. That circuit is fused on S9. - GA
