sdoolin
Nov 13 2023, 10:14 AM
It has finally happened. The battery tray in my car was repaired years ago - before I bought the car. The repair seemed solid enough to me, but it has failed and must be fixed. I will get the engine out of the car this week, and will remove gas lines and other items in the area. Is there anything specific that I need to be looking for? And, can this be repaired without collateral damage to the rest of the car?
I can't weld, so it'll need to go to a body shop, or I'll get a friend who can weld to do the repair. I think.
Al horror stories and advice are welcome.
sdoolin
Nov 13 2023, 10:37 AM
QUOTE(914werke @ Nov 13 2023, 11:34 AM)
I knew I was gonna hear that. Pics coming as soon as the engine is out.
sdoolin
Nov 19 2023, 01:40 PM
Engine is out finally snapped a few pics. I'm thinking I clean up what is here, and tack or spot weld things back into place? I really know nothing about welding. But I have friends that do.
Click to view attachmentClick to view attachment
Shivers
Nov 19 2023, 02:50 PM
If you pull off the passenger rear tire, you can see the metal behind the battery tray. Mine was eaten away including the metal behind the top tray. I cut out the rusty metal, used it as a template and welded in the shaped patch. I pulled out the tray from my 72, I had holes where I wanted to weld it to the car. Welding through the holes and grinding gave it a clean round weld. I’ll look for a pic.
The patch
Click to view attachmentThe rest of it.
930cabman
Nov 21 2023, 02:46 PM
QUOTE(Shivers @ Nov 19 2023, 02:50 PM)
If you putt off the passenger rear tire, you can see the metal behind the battery tray. Mine was eaten away including the metal behind the top tray. I cut out the rusty metal, used it as a template and welded in the shaped patch. I pulled out the tray from my 72, I had holes where I wanted to weld it to the car. Welding through the holes and grinding gave it a clean round weld. I’ll look for a pic.
The patch
Click to view attachmentAnd that is how it's done
Often times it is more involved, hold your breath
