QUOTE(mskala @ Nov 16 2023, 06:14 PM)
The 914-6 rear pads are the same size as the 914-4 front pads (early I think? instead of late).
So, you can either find 2 more small pins (1 for each side) or just turn down the ones you have in a lathe.
Back in the day I bought the PMB Aluminum copy of the 914-6 rear calipers and made
some aluminum pins (to save weight
) (All thin pins to fit the standard holes)
Click to view attachmentMark S.
Thanks Mark
I have several NOS sets of SWB 911 pads. I took one set and drilled out the holes with my drill press. Seemed easy enough and fit well. However, my rebuilt calipers from PMB came without the inner adjusters. I am waiting for a set from them.
