Carlitos Way
Aug 19 2005, 10:57 AM
It was a rough week. Work has been hell. Then, driving home from work I noticed the car seemed a little sluggish. By the time I got off the freeway there was a loud noise coming from the car. NOt sure if it's a bad "knock" or what... but it appears my car is painfully wounded. I will probably have to start looking at rebuilt alternatives.
What a sad day, indeed.
C.
SLITS
Aug 19 2005, 11:02 AM
Think in terms of valves......I'm on #3
Carlitos Way
Aug 19 2005, 11:05 AM
Thanks,
I'm gonna pop the valve covers tomorrow. I'm waiting for a frickin' Adelphia tech in the meantime, and I have to go to work today and tonight. HOwever, I will definitely check the valves. Thanks for your suggestion. Let's hope it's not a "BIG" issue.
C.
SLITS
Aug 19 2005, 11:09 AM
While it is a pain in the ass, dropping the engine and pulling the heads is not the worst. As long as the seat or valve head did not seperate and destroy the piston / barrel / head (in other words...don't drive it), it can be a reasonable fix. ( I just did one and will have to do another soon )
Carlitos Way
Aug 19 2005, 11:10 AM
Is it worth to do all that, or is it usually better/easier to replace the engine?
Cap'n Krusty
Aug 19 2005, 11:38 AM
"Loud noise"? Describe the loud noise. Could be (and often is!) a blown out spark plug, something that could be repaired in the car. The Cap'n
fatlando
Aug 19 2005, 12:07 PM
My stupid question....
Can you take the valve covers off in the car or do you have to drop the engine to do that?
there's a little knock i want to investigate too!
MattR
Aug 19 2005, 12:39 PM
Yep, the valve covers will come off with the engine in the car.
Good luck on this carlos!
Carlitos Way
Aug 20 2005, 02:46 AM
Thanks for the good wishes guys.
I'll be taking the valve covers off tomorrow. I took off the spark plugs earlier today from the right sid. So far, the spark plugs don't look TOO bad. The one in the rear is a little oil fouled, but nothing major. Will check the valve train tomorrow. let's hope it's nothing serious.
I'll keep you posted!!!
Carlitos Way
Aug 20 2005, 10:46 PM
Well... it's worse than I thought. I have ZERO compression in the #3 cylinder. No major oil puddles to speak of, and the cylinder appears to be in one piece. The valves apepared to be really loose, so I was hoping maybe it was a matter of them having rocked loose. No such chance. Guess this is gonna require a definite drop of the engine.
SGB
Aug 20 2005, 11:01 PM
sorry to hear. But after a valve job and putting the heads back on (AKA top end rebuild), if the job is done well, the improvements will be quite apparent- no smoky start-up, smooth valve train noise, generally overall smoother performance. The engine will have to come down, not "out" really. Lower the engine on a floor jack till you have fulll accss the valve covers, put a little more blocking under the engine so it wont be tippy, and take thosse heads off right there in the living room!
TravisNeff
Aug 20 2005, 11:20 PM
Sounds like the seat dropped, if there is not damage to the piston it will be a quick and relatively easy fix. I had a valve snap off the stem while driving down the freeway. Talk about a mess holed piston and a ruined engine. At least the mutha freckle who was tailgaiting me got a little surprise - piston chunks flying out of the muffler all over his car, heh heh.
Carlitos Way
Aug 21 2005, 12:53 AM
QUOTE (Travis Neff @ Aug 20 2005, 09:20 PM) |
Sounds like the seat dropped, if there is not damage to the piston it will be a quick and relatively easy fix. I had a valve snap off the stem while driving down the freeway. Talk about a mess holed piston and a ruined engine. At least the mutha freckle who was tailgaiting me got a little surprise - piston chunks flying out of the muffler all over his car, heh heh. |
IT never happens to me when I have an asshole behind me.
