Boothy
Nov 28 2023, 08:53 AM
Folks!
Looking for adjustable perches if anyone is tripping over a set. Running Koni Reds out back and her butt is lower than I want (talk about leaving the door open for comments).
Figured I'd ask.
Cheers!
carl k
Nov 29 2023, 07:57 PM
@Boothy I have these, I can't remember if they're from Koni Reds, though. Happy to check any measurements for you.
thanks!
Carl
Click to view attachmentClick to view attachment
mlindner
Dec 3 2023, 10:16 AM
Boothy, what are your springs setting on now. Adjustable perches usually mean lowering the rear. Do your reds have the groves in them. Mark
stownsen914
Dec 4 2023, 08:54 PM
When I had stock-style Koni's on the racecar, I was able to source generic circle track style spring perches that fit the Koni shock body. They were for generic 2.5" springs, so I had to replace the upper spring perches as well.
rgalla9146
Dec 6 2023, 08:17 PM
Are you using OE springs ?
