QUOTE(76-914 @ Dec 8 2023, 02:56 AM)
Listen at the tail pipe. If you hear anything it's an exhaust valve.
Listen at the throttle body.........................: it's an intake valve.
Listen at the oil filler neck..................................: it's the rings.
well said thats what I have always done ,I bought a 1.8 carb bus motor many years ago ,took a gamble as it didn't turn over fully ,this was a rush job as the owner wanted it gone that day but I wanted to run it otherwise no deal .
Pulled one head and found broken valve but little damage as it happened when the PO started it and he shut it down ,had a valve grind and new valve and put back together and it ran up fine but a bit rough as had been sitting for 3 yrs and the horrible Solex carbs were worn out.
Fitted it to my project and it just ran better every time I drove it , took it out and give it a good thrashing and it turned out to be the best $200 I every spent
This proves that you can wake them up ,even as mentioned may only require valves reseating ,good luck to the OP ,
