Stef914
Dec 4 2023, 01:21 AM
Hi all,
Lately, an unidentified noise that I used to hear on turns (both left and right) at relatively high speeds - 40mph or more - has significantly increased. Now, I can sometimes even hear it when on straights. The shop ruled out the rear bearings about 6 months ago (though they replaced the front). I uploaded a short video on YouTube, and this is the link:
https://youtube.com/shorts/M4I_bWh1NBw?si=-uT5zvKwzgs6N1XcYou can clearly hear it at seconds 00:03 and 00:17
Any thoughts or suggestions are highly appreciated.
Thanks in advance
sb914
Dec 4 2023, 08:01 AM
Cv joint ?
Usually when turning.
Geezer914
Dec 4 2023, 08:18 AM
I second checking the CV joints. How many miles on the car?
Stef914
Dec 4 2023, 11:58 AM
Mmmh a lot , 200k +
jim_hoyland
Dec 4 2023, 12:17 PM
CV related. You’re gonna have to do some disassembly and inspect each bolt, washer, CV, etc.
Could be just a loose CV, or something else
second wind
Dec 4 2023, 12:27 PM
I am no mechanical guru like many on this site....but 200,000 miles is a lot of miles.....especially if those are the original CV's......gotta' be the CV's....imho...
gg
rjames
Dec 4 2023, 01:19 PM
Even if it isn't the CV's, if they are original to the car you need to replace them.
76-914
Dec 4 2023, 03:09 PM
It's easy to identify which CV but I have no idea when it's both. If you turn to the right while accelerating it's the left side CV and vice versa.
technicalninja
Dec 4 2023, 09:22 PM
CVs or differential spider gears IMO.
By 200K I'd have re-booted/rebuilt axles 3 times...
I'd drain transmission and inspect gear oil as well.
TX914
Dec 5 2023, 06:38 AM
I had a similar rattling noise on deceleration that turned out to be a heater control valve rattling against the engine mount bar.
