QUOTE(914werke @ Dec 4 2023, 08:53 AM)
If you are running a line from the R. side impeller housing nipple to the Charc. canister you should cap that one.
Thank you both. AFAIK, all the other vac lines are hooked up per the diagram. I had the line from the cannister just dropped through the engine tin in that area as that what I thought the diagram showed. I will connect it to the port in the picture and be good to good.
Thx
