As some of you may know, I build an 80mm custom AFR gauge as a clock replacement for 911s and recently someone asked me if it was possible to build a 60mm version. I was able to fit the main board and stepper movement in a 60mm case. This is just a prototype, but it does appear that with a little work, I could make these. It would require a 60mm temp or volt gauge as the donor to get the case, face, and needle. I don't yet have an estimate on the cost, but I wanted to see if there would be any interest before I spend more time on it.
Like all of my other AFR solutions, this gauge would work with most wideband controllers including but not limited to AEM, Innovate, PLX, and 14Point7.
Sorry for the blurry picture!
