Literati914
Dec 9 2023, 04:21 PM
I bought a set of the plastic expanding "push" rivets from 914rubber - and they're a bit of a nightmare TBH. Their pins are wayyy too tight as they come, and my install ratio keep decreasing. Pins will not turn by hand or otherwise, and mostly just end up breaking when trying to tap them in. Anyone got suggestions for working with these?
914sgofast2
Dec 9 2023, 04:50 PM
Try Grainger Supply for black plastic rivets.
76-914
Dec 9 2023, 07:10 PM
QUOTE(Literati914 @ Dec 9 2023, 02:21 PM)
Thx for the warning. I bought a set and if the 1st one gives me a difficult time I'll send the lot back.
Front yard mechanic
Dec 9 2023, 07:18 PM
Just drill them clear
technicalninja
A little disturbing from my viewpoint.
I have a set coming...
I'll report what I find.
Maybe a bit of heat could help?
I'm guessing you tried lubricants?
Super clean the holes out.?
gereed75
Dec 9 2023, 08:32 PM
I recently bought a set from 914 and they were very soft plastic and there was no way I could insert them. Found some in McMaster that will work but will require slightly larger holes.
The McMaster ones are very close dimensionally and in appearance to the original just slighty larger.
mlindner
Dec 10 2023, 07:25 AM
just use metal rivets, many sizes and also in black.
rick 918-S
Dec 10 2023, 08:37 AM
Mark is going to want to know about this.
StarBear
Dec 10 2023, 12:32 PM
Here’s what I do :
clip the rod very close to the rivet head.
Trim the cut end just a bit with a utility knife.
Insert the rivet into the whole.
Slip the trimmed end of the rod into the rivet head hole.
Tap the rod into the rivet head.
A bit of a work-around, but works!
Olympic 914
Dec 10 2023, 01:52 PM
QUOTE(StarBear @ Dec 10 2023, 01:32 PM)
Here’s what I do :
But cleaned the hole by hand with a small drill bit in a pin vise, then insert into rivet and tap down.
Nate W
Dec 10 2023, 05:33 PM
I insert the plastic rivet, holding the pin with some small needle nose pliers, then gently tap with a tiny hammer to get them started / broken free without bending the pins
Literati914
Dec 10 2023, 07:27 PM
QUOTE(technicalninja @ Dec 9 2023, 07:18 PM)
I could get the rivets in the holes just fine, the soft flimsy pins though will mostly give before they'd move and not move at all. They're too tight leaving you with a destroyed rivet. And that's tapping very gently with a smallish cobbler's hammer (learned after the first one that soft coaxing would be needed). I was successful on two of the six that I tried. Hopefully you guys have better luck!
QUOTE(gereed75 @ Dec 9 2023, 08:32 PM)
I'm gonna look over there - Thanks!
Literati914
Dec 10 2023, 07:33 PM
QUOTE(StarBear @ Dec 10 2023, 12:32 PM)
Here’s what I do :
Thanks SB, but I'm afraid that would be impossible with the set I have, as getting the pin out in the first place would destroy one or both parts of the rivet.
Mikey914
Dec 11 2023, 11:34 PM
The way to install these is not intuitive.
Snap off the pun, fluo it over and push it into the rivet section.
Its pretty easy if you do it this way. I have never been able to tap it straight in, its allways slighty off, starting it manually is the only way to go..
87m491
Dec 12 2023, 07:41 AM
QUOTE(Mikey914 @ Dec 11 2023, 09:34 PM)
Snap off the pun, fluo[b][u] it over and push it into the rivet section.
Where's autocorrect when you need it? Gotta ask as my 914R rivets have been waiting for my threshold trim to arrive. Are you saying insert the pins into the bottom of the rivet before then inserting the rivet into the hole? (assumed that you insert far enough so some sticks out the top and then will be tapped down for final fitment?
dr914@autoatlanta.com
Dec 12 2023, 10:16 AM
the aftermarket ones are too big, only the factory ones fit, NO ONE wants to enlarge the holes these days anyway. buy factory rivets tear off the attached peg, put the rivet in the hole, open the rivet a bit to accept the peg and then tap home with a flat body hammer
QUOTE(Literati914 @ Dec 9 2023, 03:21 PM)
NARP74
Dec 12 2023, 10:48 AM
Are the rivets metric? I never checked. Are they available anywhere? I ran into this with some sheet metals screws. Never occurred to me to look for metric ones.
TonyA
Dec 12 2023, 12:44 PM
What color should they be. Clear plastic or black?
Montreal914
Dec 12 2023, 12:48 PM
Why would a German car have non-metric fasteners?
rgalla9146
Dec 12 2023, 03:22 PM
QUOTE(TonyA @ Dec 12 2023, 01:44 PM)
Picture for color refrence only.
Sourced from early cars for years.
Not clear, not white either.
Black came '73 ?
NARP74
Dec 12 2023, 06:35 PM
QUOTE(Montreal914 @ Dec 12 2023, 11:48 AM)
Post war many items were shared. I had a Land Rover that had 3 different thread types. Very time consuming to figure out.
But probably my UScentric way of thinking. I have to retrain from time to time.
pek771
Dec 12 2023, 07:14 PM
I think the only non-metric stuff in a Porsche or VW are the seat belt bolts.
