I got rid of my Moto Guzzi habit a few years ago ('76 850 Lemans I),
'76 850 Lemans I
but some of the power fiends in the Guzzi worlds had worked out how to twin plug the heads for high compression fun. It's pretty common to do it to those old engines. A very small Chain saw spark plug is used for the confined spaces.
For those of you not familiar, the Moto Guzzi engines are very similar in design to the BMW flat twin (old one) exept the cylinders are pulled up into a 90 V to gain ground clearance. Otherwise, its a 2 valve, pushrod, aircooled engine. (Heads are much better than the Type IVs though since they are basically Hemi's)
Has anyone had any luck with the TypeIV in applying twin plugs?
