windforfun
Dec 14 2023, 12:00 PM
windforfun
Dec 14 2023, 05:17 PM
930cabman
Dec 14 2023, 05:29 PM
QUOTE(windforfun @ Dec 14 2023, 06:17 PM)
Sounds normal to me. Is the engine a stock mill?
technicalninja
Dec 14 2023, 05:50 PM
You've made mention of this starting "kick back" ia couple of times now.
Here's a test for you.
Disconnect the primary side of the coil which should kill spark. Spin the engine.
Is the problem gone?
Another test, this one is mechanically testing the soundness of the motor mounts.
Put the car in 4th gear, engine off.
With a helper push/pull the car back and forth (it won't move far, maybe 6 inches) and get it rocking back and forth between stops. Look at engine while doing this. Is the engine moving too much? Bad mount somewhere. If a mount is completely broken the engine will move quite a bit. 4-6 inches is possible.
Reverse will change the direction of torque and is the next step.
You can sort of do the same thing using engine power and 1st/reverse. Someone's got to watch the engine as you load it both directions.
This works better with automatic transmission cars and "power braking" in both drive and reverse. On some cars one direction the engine will look like it's escaping the engine compartment...
Spoke
Dec 14 2023, 06:23 PM
I started my 2.056 on a HF dolly w/o issues. I did have the front engine bar connected so that helped stabilize the engine when running.
Jamie
Dec 14 2023, 06:39 PM
QUOTE(windforfun @ Dec 14 2023, 03:17 PM)
I don't understand how a horizontally opposed engine could have any significant "roll" unless a mount is bad?
