[size=Yesterday I was replacing the pcv valve in the oil filler breather box and a piece of the cork gasket fell into the reserve chamber and while picking it out I dropped it and it went under the box through an open passage under the box. I tried to vacuum it out but no luck. I also drained the oil and ran a wire along the bottom of the inside of the motor to see if it was laying on the bottom surface. No luck there. Does anyone know if the motor will just flip it the bottom of the motor or grind it up? If it does grind it up will.it just end up in the next oil change? I hope this has not happened to others but if it has please share your solution.
Thanks
