QUOTE(Highland @ Dec 24 2023, 08:36 PM)
- The car is a stock '73. All incandescent bulbs. No LED's.
- The old relay would work correctly for a few flashes of the turn signal, then both tach arrows would flash faintly together. Although the tach arrows would flash faintly together, I verified the actual exterior turn signal indicators operate correctly.
- The old relay would operate the emergency switch correctly.
- When I installed the new relay, with turn indicator off (in neutral position) both tach arrows would flash quickly and bright. If I turn on the emergency switch, everything would stop.
- Just to verify the turn signal relay is NOT on the fuse "box", but on one of those grommet mounted connectors that attach to the metal dash assembly.
- The original relay is much taller than the replacement. It is a Hella with part number 002479-01.
The tach indicators flashing together is a common wear sign with these old flasher relays.
The emergency switch you mentioned is the hazard switch, correct? And not the emergency brake.
With the new relay, when you pull the hazard switch, do all 4 outside turnsignals flash as well as the tach indicators?
With the new relay, when the left or right turnsignal is active, do the tach indicators flash normally?
