I'm a HUGE believer that the design of the primary tubes and their collectors have a much greater effect on exhaust flow than anything else.
The tubes have to be sized for maximum airspeed with minimum restriction.
Going too big is as bad as going to small in regards to diameter.
Primary size has to be "matched" to engine flow.
Primary length to collector is the next critical thing. IMHO the ss heat exchangers appear to be OK in size (up to 2.0l) but a bunch too long and the paired tubes are NOT 180 degrees to each other in the firing order.
I found a post by Jake Raby where he said "4 into 1 with short primaries" was best overall for a street-based performance application.
Look to Tangerine Racings design for an elegant solution to this problem.
In Chris's set up he uses fairly short primaries that go through two collectors.
His design first collects 2 pair of opposing cylinders and then collects the output from the first collectors into a single collector for the whole system.
This is a classic tri-y collector set up.
If it works like it should you get a negative pressure vacuum reflection from both collectors that can increase VE through the engine at two different RPM ranges.
There's lots of arguments "4 into 1 VS Tri-Y"...
Sometimes it seems to help.
Sometimes it doesn't.
I like Chris's design!
A well-done primary system increases VE.
I do not believe a muffler could actually increase VE over any other muffler design that had the same flow rates in CFM.
You CAN change how it sounds just not how much volume it flows.
I like David Vizard's stuff! He calls himself an engineer, he's an "engine design professor" in my book. His use of 30-degree intake seats is damned interesting to me.
Here's one on muffler design. Per his video he believes mufflers can only equal straight pipe exhaust. Gets good at the 20 min mark but whole thing is worth watching...
https://www.youtube.com/watch?v=5keTM9eyCOg
