I have brake line nuts that just got yellow zinc plated. If you dont get the bolts from Dave i could pull from a pair of calipers. I think there are two lenghts of the bolts with inner and outer bolts being different lenght.
Yes two lenghts only one is good. Other was cut to remove.
Archie
Dec 21 2023, 12:08 PM
QUOTE(davep @ Dec 20 2023, 07:57 PM)
What is the length of the bolts from under the head to the end of the threaded section. I have a few lengths in my parts.
Hi Dave,
I need the shorter bolts, that mic out at 1.770" or 44.94mm.
Archie
Dec 21 2023, 12:11 PM
P.S. I'm in Vancouver, so please ignore the US postal address. I'm at V5Z 1B5. Thanks.
davep
Dec 24 2023, 02:01 PM
Sorry for the delay. I have the bolts you need, and nuts to go with them. I'll dig a bit deeper and see if I have the tube nuts as well. I did have lots, but most were welded up to use as plugs.
Archie
Dec 25 2023, 03:53 PM
QUOTE(davep @ Dec 24 2023, 12:01 PM)
It's Christmas, Dave! Everything's out the window at this end! No panic.
Hi again, BDS!
So, here I find myself at the back-end of January with two caliper-half bolts and NO tube nuts, so I was wondering if you still have a couple of them you might want to sell me?
Hi again, BDS!
Thanks
Hi again, BDS.
Please disregard my last to you. I've found those tube nuts locally. Thank goodness, I'm way behind on this thing as it is!
Sorry to have bothered you!
