QUOTE(Rufus @ Dec 22 2023, 11:24 PM)
I’m confident doing 4 wheel alignments in my own garage. Takes some ingenuity and geometry.
I use a smooth level garage floor...
... Probably much better than a “professional” technician. After all, who cares more about getting it right?
I got between 50k - 78k(!!) miles from 3 sets of Goodyear Gatorbacks (220 wear rating) on a car owned from new to 200k+ miles. I did all the alignments - routine, after ball joint and tie rod replacements, etc..
You don't fully understand how correct you are!
I've been around other technicians most of my professional life and I don't like ANYONE else working on my car. I've got stories galore...
With understanding and patience MOST of the forum members could do their own alignments.
You're doing it "Full Monte" with caster sweeps and a bunch of measurements.
I applaud you sir!
That is the "correct" way.
As long as I have a groove in the tire tread that is symmetrical, I can save a bunch of time basing my toe measurements from it.
I'll spin the wheels and watch this groove carefully. The human eye can see variations smaller than .001. You can tell when something is off.
Most performance alignments I've seen tend to maximize caster (might be wrong regarding 914 not enough knowledge yet) and if front caster is adjustable, usually I'll max it.
Camber is taken care of with the level as you posted. I'm very careful to measure off of the outer wheel flange here.
Toe is done with a tape measure or (to be more accurate) a wood "jig" the track width wide with 12" legs. Put a nail through both uprights to allow measuring at horizontal centerline of the tire. Think wide U for the shape 55" wide/12" tall should work.
Use an 8" fluorescent bulb placed against tire horizontally to compare toe side to side quickly. With the length of the bulb multiplying the toe difference it is STUPID easy to see which side you should change. Next time you do one, try it
I'm very careful with my burned out 8' bulb. I use it for multiple things.
It's easier/quicker for me to attain accurate toe and steering wheel centering this way than using a full-on alignment bed.
I've had multiple "quicky hand alignments" taken to alignments shops that have needed little or no adjustment. I don't own an alignment bed and I always say "you should have it aligned on a machine" when I alter alignment settings after repair work.
Some customers actually take the advice and get it done...
I like the use of flat metal signs and grease for your caster sweep plates. Good inexpensive way to get the job done.
Finding flat concrete can be very challenging.
I got lucky...
I'm renting a wealthy man's first "play toy" shop and he spent extra on everything in here. Ultra-flat floors were one of his pet peeves.
