QUOTE(friethmiller @ Dec 24 2023, 11:47 AM)
QUOTE(bdstone914 @ Dec 24 2023, 10:31 AM)
@second wind
First check that the brake lights are coming on. Ignition to on. You can use a pole to depress the pedal wedged against the seat if you dont have a helper to check the lights.
The switch is in the depressed position with the pedal NOT depressed.
Adjustment is done my loosening the jam 7mm nut on the slotted screw.
Near Impossible to do with the switch installed. Turning the screw clockwise makes the lights come on sooner. I adjust them so that the lights com on when the pedal moves about an inch.
Bruce
I did this adjustment after installation and it was a b#tch!
Easier way is to remove the switch from the housing, adjust and reinstall. If nothing is bent about four threads should show above the jam nut. I adjust all switches when i rebuild pedal sets.
Most replacement switches are so far are of adjustment they will not come on and need at least three inches of pedal travel to activate.
